LTA1302-PC+ QSFP+ Optical Transceiver
CWDM 4X10.3125Gb/s 150m
The LTA1302 QSFP+ Optical transceiver is intended for the service with Multi-mode fiber in 41.25Gb/s high speed data communications and computing applications. It meets the requirements of QSFP+ MSA, IEEE802.3-bm-2015, operates from a 3.3V DC power supply and is offered in the commercial temperature range. The module has an aggregate link bandwidth in excess of 41.25Gb/s by multiplexing of 4 CWDM optical lanes, each lane capable of transmitting 10.3125Gb/s over 150m on MMF optical fiber. It is fabricated with a rugged die cast metal housing and cage assembly. The device meets the EU Directive 2015/863/EU for RoHS compliance.
LTA1302-PC+ | QSFP+ | LC | 150m | C | Single-mode | 1271nm 1291nm 1311nm 1331nm |
4x10Gb/s | -5~+3.5dBm | -10.2dBm |
High performance computing, datacom and sever data links
High speed access
40G Ethernet
4 independent optical lanes
Lane data rate of 10.3125Gb/s
Aggregate data rate in excess of 41.25Gb/s (over 4 lanes)
Hot Pluggable
150m link on MMF Multi-Mode Fiber
CWDM Laser/ Pin PD Technology
QSFP+ MSA Compatible electrical I/O
Case Operating Temperature:
Commercial: 0 to 70ºC
+3.3V power supply
RoHS compliance
